- Fri Apr 10, 2009 6:16 pm
#109683
so after taking the head off and changin the head gasket and see that nothin is wrong, i go to set the timing and put the belt on. theni tell my friend to turn it on ....... nothing so im mad all over again, so i double check to make sure i got it set right and i notice that the skunk2 cam gear is off by ALOT
^that wht its was at the night b4 it stopped runnin
^ thats where it was at when i checked the timing again all the screws moved over to the right where the arrow is pointing ( i should of taken a better pic but i was just mad )
i called honda they said check the valves to see if there bent but when i had the head off and was setting it to TDC i aint see nuttin wrong neither did my friend ..... could it just be its way off timing ? im also pickin up some wires and plugs up on the way home thinkin maybe its just not gettin enough spark if ne one has any more ideas it would help thanks
#6 member of "White sedans FTW" club
but bad bad things happend to the cam gear and cam and they will defintly need to be replaced asap the cam gear spun on the cam shaft which threw it way way off timing but i managed to get it back on and back at TDC and it started right up but i dont want to leave it on for long incase it happens again i might just put the stock cam back on but i already have another head and cam so i just need to get all the internals for it ill probly end up building that head
unless there wasn't one then there your problem for the cam gear being off timing and slipping...
