- Sat Mar 14, 2009 4:57 am
#103106
List of things you will need.
Please be sure to use jackstand
Sockets needed:
10mm
12mm
14mm
After your car is jacked up and on stands undo the exhaust bolts.
Then undo the each of the 2 brackets on both sides of your pan.
You will see a cover on the right of you pan there are 3 more bolts holding it on and 2 those bolts are oil pan bolts. Slide the Cover off and undo the rest of your oil pan bolts and it will come right off.
Sockets needed:
10mm
12mm
14mm
