- Tue Sep 16, 2008 11:01 pm
#70094
ok here is the story on my engine mybe it will help with the solution. it is a D16y7 and it came out of my old 96 civic DX hatch with no problems and 150,000 mi. then i traded the hatch for m 94 eg coupe; thats when i started having problems. they did the swap and converted it to OBD1 and added an exhaust and headers. they also added a d15 intake manifold. now when i start it everytime it bounces between 1000 and 2000 rpm then when it comes up to temp it jumps from 1000 to 1500rpm. it will also do that while its in gear and im not giving it gas resulting in a rough ride
. . now when i am driving i also at about 3000rmp at full throtle i hear a wistle ive been reading around and everyone says its a vacuum leak, but idk. now to the starting problem, if i turn it off and turn it back on in less the 10min it will start but then stall with the clutch in and then it will not start unless i give it gas the once its in gear it will be fine. please help me i think it might be a sticky throtal body but im not sure also i dont know if they replaced the intake maniflod gasket so i think that might explain the wistling when i get on it
