Idling problems
Sorry for starting so many topics recently haha
Anyway, after working my way through sorting out various leaks its now starting, running and not leaking at all which is good!!!
Problem is, i start it and the revs go up to 3k and it fluctuates between 3k and 3.5k revs. Doesnt go any higher than that though thankfully!!!
I had to replace the TPS as the old one was mangled, i dont know if this could be causing the problem?
I cant find any obvious vacuum leaks or anything else that might cause a problem so a wee bit stuck on how to sort out the idle
