- Fri Aug 22, 2008 11:20 pm
#67071
I dont have a D15B7 its a D15B8 which would explain why its so slow. All the posts I read say the D15B8 is 8 valve mine definatly says D15B8 on the block and 16 Valve on the valve cover... HMMM Can I swap an intake mani from a B7 and feel a difference ? Also what does this mean as far as a mini me swap
If you already have pistons cut for a 4 valve head, then a mini-me will be exactly the same steps as if you had a D15b7
You could probably swap the manifold, but I doubt you would feel any difference.
