- Sun Apr 20, 2008 3:51 am
#51612
Hey everyone. I know the d15z1 is an engine with almost no potential due to its really small intake valves. I know though, that the d15z1 has low compression. If I were to put the d16z6 head on it, it would make the engine compression around 7!
... so with this information, I think it would be a great opportunity for a turbo set up with about at least 8psi
Now... I need help with more information. It sounds easy, but I want my set up to run reliably and not throwing a rod or something. The thing is though, the d15z1's connecting rods are so tiny and thin! Would this turbo set up eventually break them or no? Also, is it possible to even make this set up smog legal? I live in California, and we are popular over here with our strict emission laws
. I need information on this set up. I do not want to build everything up and have it just die shortly after. Thanks again... and sorry if there was a post up like this... I didn't see it
... I would only swap to perform the turbo!... (because to turbo the z1 engine... the spooling time would be to long... and not enough power...)... If you have seen the z1 head.. the intake valves are smaller than a quarter...almost like the size of your thumb...
... Damn!... That almost just destroyed the plans I had for it!!... I still am determined to try .. but I am not made of money and I cant afford to screw up the car and just get "another motor" .. freakin a! .... I still want to do more research and homework on this build.. but in the end I might just do a d16z6 swap.. and then later on turbo THAT build... freakin A! ... thanks for your advice suspended. It honestly does help... we will see what happens..
