Howdo i tell what engine the head came from
PostPosted: Sat Mar 22, 2008 7:47 pm
by babyblue50
I have a d15b i just installed and a blown d15b7 which i want to rebuild some day, i broke a rod. I also have a sohc vtec head and i would like to figure out what block it came off of and what car it came from. also the d15b, does anybody know what it came out of year model same with the vtec head
PostPosted: Sat Mar 22, 2008 8:30 pm
by asianrob
should be able to tell by the casting marks on the head by what year and the code for it example
PR3-3 (circled in yellow
year 9/2 (circled in red) i think is the 3rd circle that says the year
Etc...
keep in mind that is a b-series head
D-series head should be similar
awsome! here is what i found.
PostPosted: Sat Mar 22, 2008 9:20 pm
by babyblue50
p08-4 and 9/3 1/0 1/8 /7 but each pair of numbers is i the center of a circle except the 7 the is no first number any info please
PostPosted: Sat Mar 22, 2008 9:22 pm
by LowTEC-Derbo
p08 is a z6 stamp. 93 d16z6 vtec head.
p06 is a d15b7 head.
thank you but does any one know about d15d
PostPosted: Sat Mar 22, 2008 9:34 pm
by babyblue50
thank you the d15b is it from japan and if so what year there is no 4th only d15b
does this sound any good
PostPosted: Tue Mar 25, 2008 12:53 am
by babyblue50
d15b block with the d16z6 head, can you tell me any info. what am i looking at hp stock, also displacement. where can I find specs on this block and head
Re: does this sound any good
PostPosted: Tue Mar 25, 2008 2:00 am
by KRYSTED9354
babyblue50 wrote:d15b block with the d16z6 head, can you tell me any info. what am i looking at hp stock, also displacement. where can I find specs on this block and head
if u do that setup and get a smaller { THINNER} gasket and hone the cylinder walls mabey if u got money get new rings and at least polish up the intake and exhaust in the head u will get 120 or so
PostPosted: Tue Mar 25, 2008 10:05 am
by LowTEC-Derbo
where did you get a number hp from? Is this based on experience? Cause guestimating hp is ridiculous. :)
Only sure way to get a guestimate is from a dyno. Even those are inconsistence with numbers.
http://www.zealautowerks.com/dseries.html
here is a nice calculator to help with your build. It has some specs in it.
