Online Store were bay ECU Conversion jumper harness
PostPosted: Thu Aug 20, 2009 1:06 pm
by Ylts
conversion OBD0 to OBD1 for mini-me swap
ylts form estonia
PostPosted: Thu Aug 20, 2009 3:08 pm
by chrono404
Not sure on the question. If your building a minime with a OBD0 block you just need to use an obd1 alternator and a distributor.
All D Series Vtec Heads are OBD 1(d16z6,d15z1) or OBD2(d16y8,d16y5)
If you just want a jumper harness rywire sells quite a few different ones. HERE is the link his EG Section.
If this is a different question like you want to put a OBD1 Minime into something obd0 such as a EF or CRX rywire also makes conversion harnesses for that as well.
PostPosted: Thu Aug 20, 2009 3:24 pm
by Ylts
I´m building mini-me d16a6 block, D16Z6 head, and p28 ecu. Or use EH9 0bd1 wiring( Underhood, Dashboard).
PostPosted: Thu Aug 20, 2009 3:56 pm
what model & year civic is this mini-me going to be in?
PostPosted: Thu Aug 20, 2009 9:23 pm
by Ylts
4th Gen saloon 89a
PostPosted: Fri Aug 21, 2009 1:21 pm
So I think you would need this to use a P28 obd1 ecu in your chassis harness:
http://rywire.com/store/obd0-obd1-conve ... f123b837f7
and this to go from your chassis harness to your engine:
http://rywire.com/store/8891-crxcivic-d ... f123b837f7
if your current setup is DPFI (2 injectors)
PostPosted: Fri Aug 21, 2009 3:00 pm
by Ylts
tanks for help. order there
