d15b7 rough idle and stalling!!!
This all started when I got the car back after it was stolen.
-When I turn the car on (1st time cold) the engine revs like crazy between 1k and 2k
* After i turn it off and then restart it, the engines runs smoothly just above 1k
-Got a CEL and after testing got a code 16 = Fuel Injectors
* I realized one of the injectors wasn't clipped all the way in
* CEL went away
-When driving drives like normal but doesnt go past 50mph...when I try she just revs high...im thinking the timing is messed up. The real problem is after warming up to normal temp. As soon as i get stuck at a long stop the rpms drop and the car starts to shake then ______ the engine stalls.
- Try my best to pull into the corner with the left over momentum lmao
. Then drop it into neutral and restart it , then quickly drop it to D1 (cars auto) ,or else the car cuts out in D4, i accelerate hard and quickly brake and change to D2 then D3 and finally D4. If i dont she just stalls out.
Does anyone know where I should start to find and fix the problem?? (if ur still here after that long a** write)
* CEL went away
