- Mon Jun 15, 2009 3:54 pm
#123112
how would the transmission cause or add to this type of problem? this similiar thing happen to my 95 auto civic, that my stepdaugther drives around, yesterday. she said it was driving fine 1min and then started sputtering and she wasn't able to go too fast or over 40ish, then it stalled out. she was able to pull into a parking lot, waited awhile then started the car right back up, drove some more and then sputtered and died again. when i got there i started it right up and drove back into the lot and let it idle until it died a sputtering death. i thought it could be the usual culprits, clogged filter, plugs, wire, pump, iacv or tps. but when i checked the tranny fluid, there was practically none. so i added 1.5qts, let it sit for awhile and started it back up and let it idle for about 15mins, still surging a little before i drove around the lot. it moved and drove with a little hesitation, but still sputtered, idle surging and stalled out when i parked it. i managed to change the plugs and wire, and got a new filter to change later today, and also poured seafoam into the tank thinking either the filter was clogged or it was some bad gas.... been raining alot down here in south FL and the area does flood abit and water could get into the gas station tanks. not to damage anything further, i had the car towed home, and then drove it, with hesitating, into the driveway. it feelings like the car isn't getting the right amount of gas to go or keep a steady idle, like the filter is clogged or the pump is not pumping right.
could something electrical on the transmission be causing this? also, the speedometer stopped working and that's happened before, but i checked some connections on the tranny and it started working again. i swapped out the cluster for one that has the tach on it about 3months ago and that when it happened before.
sorry for the long read, but wanted to give as much info as i could.
REd93sI wrote:just thought i would add something due to the fact your car has an auto. The trans could be failing to come out of lock-up and stalling the engine. I would check the condition of the trans fluid ie; (burnt smell / color), just as a precaution.
