marvinp8700 wrote:don't get butt-hurt dude... it's the internet
still need to rewire or get a new connector to fit the solenoid. any know a part number/if any plug (off of vtec) will work from junkyard?
Also some news! I gots me a p28 for free!wheee! freind had one from his del sol like 7 years ago! looks brand friggen new! Sweet!
suspendedHatch wrote:I'm pretty sure you can use just about any VTEC solenoid plug. Or just find a Civic EX in the junkyard and cut the plug off.
There's plenty of threads about wiring VTEC. It's the same whether it's for a B16, B18, D16, etc. There are two pins on the ECU. One is for oil pressure at the solenoid, that needs to see ground. The other controls VTEC by grounding that wire. Join them together and run that wire to one of the wires on the solenoid plug. The other isn't necessary.
Then i need to know which wire goes to which pin on the ecu.
