- Sun Apr 20, 2008 7:50 pm
#51716
flyinryan122 we might have to meet up cuz you're the only person I've seen from Utah and I just moved here.
I doubt those foam filters do much of anything. What is the spec in microns on them?
It's my opinion that you do it right or not at all.
Custom made plenum is the way to go for a daily driver. You'd have the added benefit of drawing cooler air from outside of the engine bay.
Its funny that you mention using the 20V 4AGE throttle bodies because that's exactly what happened to the ones that were on my engine. Gave them to a buddy for his B16 and later he sold them so they're probably still circulating around somewhere.
Get a standalone and do a TPS based calibration. If you wanted to retain a speed density system, you'd have to find a spot for the IAT, and then tap vacuum lines from each of the throttle bodies between the throttle plate and the head to a vacuum tube of at least 1 inch in diameter. And then you can feed all your vacuum lines off of that, ie fuel pressure, brake booster, map, etc.
