- Sun Mar 01, 2009 8:42 pm
#99712
Information is already on the site, however what you need is the following, Assuming the car you have now is already a stick shift:
>- 94-95 B18b1 Make sure all the sensors are intact, especially if its a JDM engine.
>- 94-01 B Series Transmission, If N/A I recommend a B16 Tranny, if Boosting a GSR or LS Transmission would be advisable.
>- 94-01 Integra Shift Linkage
>- 94-01 Integra Axles
>- 94-01 Integra Mounts
>- 94-95 B18b1 Ecu, You can use a Chipped ECU in place of it if its programed to run the B18.
>- B Series Exhaust Header
If you get whats on the list its pretty much pull the old engine, drop in the new one, and plug the wiring together. Easy swap. Can be done in an Afternoon if you know what your doing, if not then give yourself atleast a weekend.
