- Wed Feb 11, 2009 2:52 am
#95608
the actual bolt head is broke off
- Wed Feb 11, 2009 2:55 am
#95610
Any way you can post a pick I guess Im a lil lost on what you are talking about lol.
- Wed Feb 11, 2009 3:02 am
#95611
i would have to tomorrow if it doesnt rain
- Wed Feb 11, 2009 11:43 pm
#95835
Yes, first try an easy out bit. How it works is its threads are backwards, when u use it in a drill it will sink itself into the broken bolt and then when u reverse the drill, it will lock into the bolt and attempt to spin it out. I tried this when my valve cover bolts broke and the bit broke because u have to use a small one.
If this doesn't work, your next choice is the drill out the old bolt (hard as balls) and re-tap the whole.
I got the point where i said fuck it and left it alone, i now use a valve cover gasket as well as RTV sealant (or honda bond)
Best of luck.
Best of luck.
- Thu Feb 12, 2009 12:14 am
#95838
my old motor (as of yesterday) had the same problem, i need to try this in case i want to rebuild it
