- Mon May 11, 2009 2:36 pm
#116041
I'm finding different information all over so I'd like to get this figured out with help from civic-eg.com
The first difference is 96-00 D series oil pans have the dip stick on the front corner by timing belt vs in the middle of the front as the 92-95D series do.
Also the 96-00 D16y5 and D16y8 oil pans are aluminum instead of steel.
92-95 Oil pans all use the same bolt pattern (unsure if the aluminum 96-00 will fit or if modification is possible to make them fit.)
Here's where I am unsure... I know the pickups are different between the D16z6 and the D15b8. I put a different oil pan on my D16z6 and it was too shallow to go all the way on because the 16z6 pickup hung too low. I had to dent the oil pan about 3/8" to get it to clear the pickup. I don't know what pan this was, just said 92-95 D series, but it came from an engine where the pickup did not hang as low as the D16z6. Although I got this pan to fit by denting out the area where the pickup sits, I am thinking that this pan holds less oil than the z6 pan which ha me thinking twice about using it.
I'm not sure where the D15b7 and D15z1 and JDM D15b Vtec stand when it comes to oil pans.
With everyone's experience here, I'd like to put together a reference thread. Eventually with pics for comparison.
My 1992 SOHC Turbo Hatch
