- Sat May 02, 2009 1:38 am
#114409
hey guy
i did a swap into my eg not too long ago
i swapped a d16z6 into my 94 cx
im having a issue with my final motor mount
its the drivers side upper mount. the one you can see from the top
the studs on the engine are a bit smaller then the holes on the frame
i was wondering if any one else had this issue?
if not any recommendations on hat i should do?
i could probably hone the holes out a bit to make it fit..
will that weaken the mount?
any advise would be helpful
