- Wed Feb 11, 2009 5:44 pm
#95744
teal_dx wrote:How do you measure everything to be sure that all angles are precise and square? And what kind of welder do you have?
Awesome work as always
I take fixed reference points on the chassis, now remember that no chassis is straight and no chassis is the same, but if you keep it referenced to the chassis points it's built on, you will be ok, a few mm off is not an issue, if I measure unmodified chassis' then I also see mm's of difference in components. and sometimes it needs a few mm's off to be straight for the eye/bubble, because the chassis is off a little.
Also remember that the rear suspension setup is changeable and setteable by camber/toe in etc. but all this I've built is level and straight by bubble and re-measured, it had a difference of 3mm between the left and right lca point, but changing it to zero gave me a worse offset in another plain, which was not acceptable to me.. you cannot see the offset, just by measuring...you find out
I use a professional mig welder that was built in The Netherlands by Lasair.
