Post YOUR Sedan here
By Leppy
#347727
By Axix23
#347743
By Andre3th0u
#347744 this is my dash transformation, lots of pictures as it progresses.
finished product
new shift extension and shift knob
leds installed, need to order others with a wider beam pattern but these will do for now
all in all, i am satisfied with how it all came out, i barely had enough vinyl so thats why i had to do 2 separate pieces, a few creases here and there but its whatever. it came out looking nice and different.
By Axix23
#347750 Looks great man!!! What LEDs did you use for climate control? My gauge cluster LEDs didn't fit inside my climate control sockets.
By Andre3th0u
#347751 http://www.superbrightleds.com/moreinfo ... -base/226/
i used these in cluster and in the heater controls, they didnt seem to slide completely into the stock bases in the heater unit but they worked, the beam pattern is too focused straight ahead in my opinion and causes hot spots so eventually i will do it again and replace with a larger and wider output bulb.
