and ya it has less displacement but if ur gna turbo it ur gna want to put bigger injectors on it anyways. go with the B u wont be dissapointed! i was told the same thing and im not!
- Tue Aug 21, 2007 12:14 am
#20519
I had to make the same decision, "boost or B?" and "B16 0r B18?" i went with the B16A2 with the LSD tranny and i love it!
the swap was way easy and jst with an intake and exhaust i hung with a prelude door to door he maybe had a foot on me.
- Wed Aug 22, 2007 1:46 pm
#20776
Hehe, I'm almost certain I'll swap to a B16 first, then do a boost-project.
If you do it the other way around, it's gonna cost you twice for things like the turbo manifold, doing the ECU, etc.
I've got some pics for you guys btw, I hope you enjoy them ;)
I'm prob. going out tonight, looking for a nice place to shoot pics in the dark ;)
The hood and the spray-painted windshieldwipers + plastic cover underneath it;
Looking good IMO
Left side;
From a distance;
What's to bad about the hood, I can't get it properly in place, anybody has a tip for me?
Things to do now;
- install my D16Z2 camshaft
- buy and install an adj. camgear
- have the ECU reprogrammed
- collect the black sportseats from Bouli
- collect the lightweight flywheel from Bouli
That's enough updates for now I guess, shouldn't overload you guys with to much of them should I
Looking good IMO
Left side;
From a distance;
Things to do now;
- Thu Aug 23, 2007 3:03 am
#20833
Looking good stefan!!!
What's wrong with the hood? It looks fine to me...
Or do you mean the small gap on the last pic? I wouldn't bother if I were you, if you try and correct that, you will only screw up someplace else...
Back in Holland...
- Thu Aug 23, 2007 6:20 pm
#20892
if it isnt a VIS hood no other cf hoods have perfect fitment
TEAM OUTKAST since AUG 2007
NORCALTUNERS.COM
CIVIC-EG.COM
NORCALTUNERS.COM
CIVIC-EG.COM
- Fri Aug 24, 2007 5:24 pm
#21007
probably one of the lucky ones!
NORCALTUNERS.COM
CIVIC-EG.COM
Bouli wrote:i've got a "cheap" cf hood from blast-it.. fitment was perfect after a few minor adjustments (adjustmends ?)
NORCALTUNERS.COM
CIVIC-EG.COM
- Sat Aug 25, 2007 1:29 am
#21084
It's VIS allright...
There's a meeting at a company who sells these hoods, september 9th.
Hopefully they have some time to get it right, because I suck at it
chnzgoofball wrote:if it isnt a VIS hood no other cf hoods have perfect fitment
- Fri Sep 07, 2007 7:16 am
#22512
The hood is now much better, took me 2 or 3 hours...
After the accident of the car this hood was on first (for about 2 or 3 months), only the right frontpanel and the hood weren't damaged.
But the hood was off, so it wouldn't close unless you pushed on it.
What I did was a bit rough... open the hood, put your hands each on one corner, and give it a few janks...
That did a whole lot for fitment.
I also put rings under the frontpanels, so they sit higher.
And what I still am going to do; take a bucket of hot water, and one with cold water...
First throw the hot water on the hood, push it in place, then fixate it again with cold water...
You know what they say... good is not good enough, perfect is a good starting point.
- Tue Sep 11, 2007 4:28 pm
#22918
those seatss almost look like bride bix.. nice!
- Tue Sep 11, 2007 5:13 pm
#22922
nice for the seat belts!!
oooo for the flywheel and cam
NORCALTUNERS.COM
CIVIC-EG.COM
NORCALTUNERS.COM
CIVIC-EG.COM
