By Death_Blooms
#107905 I'm needing some sort of electric oil pump for a remote turbo setup. It's not a normal setup as you might imagine. I'm not doing like the STS systems that still use the motor for oil supply, rather setup a seperate oil tank.
Was looking around and most places use scavange pumps like on turbo bikes and quads. STS uses one to pump oil back to the engine. Will that type of pump be able to feed a turbo the 20-30ish PSI it needs to stay properly lubricated?
I've got pretty much everything I need but appear to be failing at finding something useful on google.
(Yes, I am aware of all the pro's and con's of a RTS. Do not let this thread turn in some sort of pissing match about how the setups arn't that great)
By Death_Blooms
#107974
teal_dx wrote:http://civic-eg.com/viewtopic.php?t=4505
There's a guy in here with a similar setup. I'm not sure what pump he used, but it was a couple hundred bucks.
Good shiz, it's a start. I'm just not comfortable tryin to pump oil 12ft back to a oil pan lol
