AlxMic..?
PostPosted: Fri Feb 20, 2009 4:30 am
by N1G3L
http://www.alxmic.com/uk_turbo_honda3D.php
anyone used/heard of this company?
if so, what is the feedback?
good points/bad points..
thanks 8)
PostPosted: Fri Feb 20, 2009 5:21 am
They don't say what brand anything is o I'd guess it's on par with an ebay turbo kit. So alright but don't expect it to last...
I don't know if i would trust a company that also sells an "electric turbo supercharger":
http://www.alxmic.com/uk_turbo_cat_superchar.php
edit: nm they said it is a turbonetics cast housing
PostPosted: Sat Feb 21, 2009 3:43 am
by N1G3L
seems a good starter kit though?
for the price, i mean its got a good amount of gear, even if the turbo is wack.. lol
good enough for a starter kit?
PostPosted: Sat Feb 21, 2009 5:32 am
by boosted94
I would have to go ahead and say pretty decent starter kit. and for the price so what if the turbo shits in a season. Dont forget the essentials. ARP rod bolts, head studs and a steel head gasket. Also you will need a map sensor good for boost.
Stock good for 15psi thats actual psi and with atmospheric being ~14.7psi you have room for .3 boost psi.
Things to keep in mind.
PostPosted: Sat Feb 21, 2009 7:11 am
by Sentry
boosted94 wrote:Stock good for 15psi thats actual psi and with atmospheric being ~14.7psi you have room for .3 boost psi.
At first I wtf'd, then I realized you meant the MAP sensor. :lol:
PostPosted: Sat Feb 21, 2009 10:57 am
by LaMbErT*
i want :thumb: Theres something about it that just seems cheap like ebay cheapness but who knows maybe it all is genuin good parts :?
PostPosted: Sat Feb 21, 2009 11:58 am
by N1G3L
yeh cheers Boosted94.. 8)
well the first things that attracted me were the amount of equipment for the price, cast iron manifold and the turbonetics cast housing.. and with the little research iv already done IIRC, thoughs were the major problems with the eBay specials.. manifold and housing on the turbo crack due to poor quality?
also had a friend experience that problem with the XS power kits :thumbdown:
so with a bit more research and if its all legit, i should be looking into purchasing one of thoughs AlxMic kits...
PostPosted: Sat Feb 21, 2009 1:53 pm
correction, the stock MAP is good to 11-12 psi, not 14.7
:wink:
