- Fri Dec 26, 2008 4:10 am
#85521
Ej2-B16a wrote:rofl.
7-8 safe on stock w/ tune. (ofcourse a FMU or injecotrs)
10-12 safe on water/meth injection and tune.
but thats my 2 cents.
FMUs arent that great. ive heard bad stories about them being complete crap.
when i had my single cam boosted on a baby ass ihi turbo(7psi) comparing it to my car now it was a little faster so im assuming since it was lighter than my rsx it had around 150-160whp depending on dyno, alt., etc.
with a t3/t4 turbo or similar i wouldnt doubt you could run 8psi and get away safely with a good tune.
other than a vtec controller you could buy a chipped ecu from phearable.net and search around for some .bin files that people put up of their similar tunes and start with that and see what kind of a/f readings you get. eventually you are going to want to get it profeessionally tuned either street or dyno and you could use either chrome or uberdata which are both free tuning softwares.
as for parts needed aside from what you get with the kit:
downpipe (if not on the kit)
wideband o2 (recommended)
boost gauge/oil press. (whatever gauges you feel is necessary to have)
gauge pod
injectors (450cc to be safe)
resitor box or inline resistors (im not sure if the b16a is peak and hold or saturated)
oil pan gasket for when you take yours off to tap it for the oil return line
oil feed line and return line (if not already on the kit)
oil filter adapter plate (used to run oil feed line from and oil press. gauge if you have one)
wastegate (if not already an internal gate)
vacuum hoeses/fittings
tune
thats all i can really think of.. im probly forgetting somethings but thats mainly it. as chrono said homemadeturbo has A LOT of different set ups you could use and take ideas from or gather more parts that you may need.
"if sparks dont fly, you're too high"
