Turbo Set Up Help
Fri Oct 17, 2008 10:15 pm
by JlaudioEGFreak
I apologize right away if this is a noob question but as far as turbo systems go i know not very much. But here is my questions i recently picked up soem parts to make a turbo kit for my d16z6 i have the t3t4 turbo the intake manifold the intercooler the waste gate and the blow off valve... besides the tubing what else am i going to need to get this turbo kit on my car and working right.
Sat Oct 18, 2008 1:52 am
by Classiccarsrule85
A good tune will get her working correctly....
Id also look into some DSM turbo injectors(eclipse,talon,laser as long as they came with the dohc turbo the injectors should work under the boost im thinking your going to be at since they flow a fair amount of fuel.....
now im unsure of the intake manifold you have im guessing you meant exhaust and im still unsure of what you have unless you ahve a aftermarket one the honda hf/std/cx,vx one will work and you will ned to get a adapter plate made either by you or by finding it somewhere.....BMC racing products makes it according to the magazine im holding....
You will need oil lines a way to tap and plug your oil pan to drain the oil from the turbo as well as get oil to the turbo probaly via a sandwich unit
a good air filter but i know u knew that one
wouldnt hurt to get a good couple of guages fuel pressure, boost, as well as oil psi just to be safe
And if you are still unsure and you can get your hands on the 7th edition of project tuner car its the july/august edition of '08 they turbo a CRX on a budget and its pretty much what i am doing as well as what you are doing but on a obd0 car and a 88-91 civic which makes the down pipe alot harder to make.....
