i am bolting up my turbo, i need to line up the b.o.v, wastegate, manuel boost controller, what is the proper vaccum set up for all of them in other words where do i run them to?
Posted: Fri Jul 18, 2008 1:19 am
by JMan8108
For the wastgate you should run it to the fitting on the compressor housing. For the MBC put it in that wastegate>compressor housing line. For the BOV just find a line off of your IM, your best bet would pry be to use the evap line bcuz it leaks boost if you dont seal it anyway.
