- Sat Feb 02, 2008 2:26 am
#40489
how much bosst can i run in a stock sohc zc engine without worrying about it blowing up?
Remember when Civics were cool ? Yea me neither
LowTEC-Derbo wrote:daily driven for most ZC would be around 200whp be the safe magic number.
Gorveatt wrote:*looks at hand* so what do you want to do baby
perez_tamayo wrote:is it safe to run that much boost with stock internals?
perez_tamayo wrote:what should i use to tune?
Cheap/Fast/Reliable - Choose 2
chrono404 wrote:Good, Turbokit, and "Not to expensive" Normally dont go together that well.Cheap/Fast/Reliable - Choose 2
Stay away from eBay. 99.7%(not an accurate number) of those turbos wont last you. Some people selling good name brand turbos there might be okay. then agian they might not be.
If you want a Good Turbo kit for cheap. The easiest way is to piece one together yourself. You will want to research everything very well. I have been researching Turbo Info for over a year now. I have yet to buy any Turbo parts. However the down side of this is you have to know Exactly what you are doing.
If you don't want to put the time into researching, then buy someones pre made turbo kit. I don't have any locations. Google will help you though.
Things to make sure that are in your Turbokit:
- Turbo Charger (if you want 200hp or less, get a t25. If you want more then 200hp, get a t3 or t3/t4. If you will also use this for Daily Driving the t3/t4 will take longer to spool, It will also have a higher spool point which will be better for freeway cruising)
- Front Mount Intercooler (FMIC)
- Blow off Valve (BOV)
- All of your Piping.
- Oil/Coolant Lines
- Wastegate (Internal Wastegates will be on some turbos, Some will have External Wastegates)
Recommended:
- Boost Controller. I recommend Electronic. Research the brands find the best one that will fit your needs.
- Oil Catch Can/Breather (How to on this site on how to make one)
- Blow off Valve - This should come in a kit. If it doesn't buy one. This will prevent compressor surge, Which can destroy your turbo.
Turbo Research Sites:
http://www.homemadeturbo.com - Random Porn on Forums. Be Careful on there
http://www.turbod16.com
If anyone else can think of anything else feel free to post addons to this. However that list will give you a good idea what to look for.
