jrsc builds
hey every1 you always here abot turbo builds and dyno numbers does any1 have a good sc build like b seriers ect and what is the most power to be had sc can u hit 300
HeikDiesel wrote:Little update on this. Car made 282 with better fuel on an all stock b16. I bet with very little modification I could hit 300.
xhardlinerx wrote:HeikDiesel wrote:Little update on this. Car made 282 with better fuel on an all stock b16. I bet with very little modification I could hit 300.
Can you explain what you mean by better fuel? Are you saying 282 whp or at 282 at the crank?
Thanks
92dxeg wrote:cuz iam up inm the air with what the cp ratio will be i think iam leaning towds 9.1 do u thinlk thats good for sc cuz ik wit a sc it takes power to make power and 9.1 would lower the hp a little would it not ?
HeikDiesel wrote:I never wrote that the car made 299. The first tuner got the car to make 229/166. With E-85 compared to e-70 and a better tuner I was able to make 282/204 out of it. I'll post the full chart later. I'm at work and they block photobucket.
How are you going to get 15psi out of the JRSC? I already have belt slippage at just over 11. I think 15 would be a bear to even get on the 1.6, let alone the 1.8.
