filter sandwich/oil cooler adapter
PostPosted: Wed Aug 29, 2007 12:36 am
by sihatch9508
im wanting to get one to fix my leaky oil fittings problem.
http://www.glowshiftdirect.com/index.as ... ategory=37
what i want to know is what size do i need to get? and is the oil filter sender adapter better or worse than the oil cooler sandwich adapter?
PostPosted: Wed Aug 29, 2007 1:19 am
I bought that brand for my turbo setup. The quality is ok for $30. be sure to wrap the small bolt threads with teflon tape good or they will leak. If you plan on running an oil cooler then get the one with the oil cooler adaptor fittings. But then you gotta buy an oil cooler too.
I don't know which size is for civics, I got mine from their ebay auctions:
http://cgi.ebay.com/ebaymotors/OIL-FILT ... enameZWDVW
PostPosted: Wed Aug 29, 2007 2:22 am
by chnzgoofball
hmmm... didnt kno they made something like that... :?
PostPosted: Wed Aug 29, 2007 2:25 am
by LowTEC-Derbo
if you are going oil cooler, you should run a thermostat because it will make it harder to raise your oil temp to running temp without one.
There are thermostats that set at 180F to open.
PostPosted: Wed Aug 29, 2007 3:08 am
by sihatch9508
teal_dx wrote:I bought that brand for my turbo setup. The quality is ok for $30. be sure to wrap the small bolt threads with teflon tape good or they will leak. If you plan on running an oil cooler then get the one with the oil cooler adaptor fittings. But then you gotta buy an oil cooler too.
thanks. i just orderd that one.
so im assuming it just screw in over the existing spindle correct?
PostPosted: Wed Aug 29, 2007 1:12 pm
exactly, the new piece screws into the original one, and then you screw the oil filter onto the new piece.
PostPosted: Thu Aug 30, 2007 2:04 am
by sihatch9508
thanks, you the man teal!
