- Thu Jun 03, 2010 3:34 pm
#198484
arp dosent make an off the shelf kit for a non vtec d series off the b7/a6 platfrom... but they are very customer oriented, you may be able to contact them and they could either make you a kit of possibly have a stud the right length to fit that will work for your app., also a quick upgrade for your b7 would be to pickup a cam from a d16a6 (crx si engine) ive heard its a cheap upgrade for those engines...
on a side note, i have heard of over boosting before and that supposedly can pull the valves open causing valve to piston contact, because your boost amount is greater than the stock spring pressure... but i havent seen it first hand, ive just heard it before
PANDA CREW No.20
