- Sat May 22, 2010 2:53 am
#196093
Hey guys so a little background Im new to this sight but not so new to the civic seen, had my first civic right at 15 it was a 2000 si conversion with b16a2 and all the goodies had to sell my baby in order to get a cherokee because i was movin to northern minnesota for college football, well blew my knee out and am starting work back in AZ and its ALL going to my car and am getting a 95 ej1 with a b18c swap and really looking for some advice on the turbo build i want to do...
Ive done a shitload of research and this is what ive come up with
starting from bottom to top
Engine:
Crank micropolished
block sleeved
Cp pistons 9.0:1
eagle rods
Greddy head gaskets and seals
the head port and polished
3 way valve job
ARP studs
Skunk valves and springs
skunk stage 2 cams
AEM cam gears
Skunk valve cover
AEM fuel rail
Rc 750cc injectors
walbro pump
oil cooler
Turbo: I know I want to run a gt3076r
Is there any turbo kits out there that already run this??
or do i have to purchase a t3/t4 setup and simply replace it with this turbo and have a manifold custom made??
Any other advice on this build would really help guys I want to do it the best way I can and make about 450
So an advice you can give would be great Thank you!
Engine:
Crank micropolished
block sleeved
Cp pistons 9.0:1
eagle rods
3 way valve job
ARP studs
skunk stage 2 cams
AEM cam gears
Skunk valve cover
AEM fuel rail
Rc 750cc injectors
walbro pump
oil cooler
