- Thu Nov 02, 2006 9:46 am
#430
So why is it that soo many people tell me to stay away from FMU's?
- Fri Nov 03, 2006 1:51 am
#432
FMU's are cheaper than hondata, uberdata, AEM, crome, etc. but not nearly as accurate. If you are running a low budget turbo setup and don't plan on much boost, than an FMU will work. But if you spent big bucks on a setup and plan to run a lot of boost then definitely stay away from FMU's.
- Fri Nov 03, 2006 12:17 pm
#438
so can an FMU support 15psi?
- Sat Nov 04, 2006 8:34 am
#447
so how much $ does uberdata, or hondata, or chrome, run for?
- Sun Apr 15, 2007 5:37 pm
#5610
do some research before you have anyone touch your car. hondata is your best bet, but is very costly. uber and crome as well as others are freeware but someone will have to tune it for you just like the hondata.if you can find someone to tune freeware for you, make sure they have done it before. which is best? they are all pretty good....now it's time to decide...
flyinryan122 wrote:so how much $ does uberdata, or hondata, or chrome, run for?
- Sun Apr 15, 2007 6:49 pm
#5622
fmu's i would say work best with turbo kits that are smog legal such as the smog legal greddy kit which comes with one and the edlebrock kit which also comes with one... but if u go custom turbo setup i say pay a little more for better tuning but this is in my opinion only tho...
TEAM OUTKAST since AUG 2007
NORCALTUNERS.COM
CIVIC-EG.COM
NORCALTUNERS.COM
CIVIC-EG.COM
- Thu May 10, 2007 9:09 pm
#7693
if you want to rebuild your engine after you put on an FMU because you ran lean and melted your pistons go for it. there junk!!! for the price of a good FMU your talking about $300. for a little more you could have a fully tunable ECM.
- Mon May 21, 2007 1:12 am
#8397
Get Chrome, it's free, and then get on Honda-Tech.com and look up Matt Schue.
What injectors are you running? If you are still using stockers, you may need to run with the FMU until you are able to get something bigger than can be controlled better via the ECU and Chrome program.
- Sun May 27, 2007 10:49 pm
#8980
Sorry for bringing up an 'old' topic...
I wouldn't boost at all untill I'd get my hands on a decent EM.
FMU's suck, to rich or to ehmm, stoich? (not enough fuel) and you'll end up with a lot of damage.
For the rest, see chicken rapp's reply
- Sun May 27, 2007 11:32 pm
#8985
Word you're looking for is lean
But i have no idea about this topic so will keep my mouth shut
stefan wrote:stoich? (not enough fuel)
- Mon May 28, 2007 10:35 pm
#9012
An AFC hack will also kill your engine.
It fools the ECU, wich also has some unwanted side effects, can't remember wich ones though.
I do know, that when you are going to boost, spend that few extra bucks on decent injectors and a good tune, pref. on a decent dyno.
The money you pay more with proper tuning, is money well spend and will save you a lot of money in the near future.
It also tends to make it run better, faster, stronger, longer, etc. etc.
- Tue May 29, 2007 6:40 am
#9033
X2 !!
Same as always, you get what you pay for.
the benefit (do i spell this correct ?
) of using an good management is that it can be fine tuned to meet your car requirments.
(my english suck my bad)
stefan wrote:An AFC hack will also kill your engine.
X2 !!
