- Mon Dec 14, 2009 9:05 pm
#161868
ok as some yall know i planted a b18b1 into my sedan. now its all bard and only needs a smog and im done for 2 more years. i have my built motor- b18b1, b16pistons, new rings, bearings, gaskets, head is ported and polished by JGperformance, crower stage 2 cams, dual valve springs, aem cam gears and thats it in a nutt shell. what my question is, i know ill want more power than what will be coming, will it be safe to run a turbo? is it worth it? is the compression already to high? i will be adding a new throttle body, manafold and will have to upgrade the injectors an proly the fuel rail to. plus i will have crome or hondata installed then dyno. so any advice will help. and if possible what will be safe boost? 8psi 15psi 25psi
