- Thu Nov 26, 2009 11:20 pm
#158577
about to boost my car in about 3 or 4 hours...literally
got the intercooler mounted and all the intercooler piping ran...im using a hf mani with adapter plate and 14b...just a little fun till a get my other stuff finished...vitaras eagle h beams built head...the whole nine...ive never used an fmu and always done things the right way...my quiestion is if i get everything mounted up and ready to start i should be ready to go..i have my walbro in and ill have the fmu installed...the stock map sensor should be fine for up to 11 lbs correct? ive heard of getting a check valve and runnin that between the map sensor and the throttle body so the map sensor wont see boost...
