- Sat Oct 31, 2009 6:44 pm
#154007
So took my b18b1 block over to the machine shop yesturday and i was telling him i was gunna use arp harwear he was saying somthing about if i use arp studs for the main caps, than i would have to spend like 150$ more on some other machining needing to be done.I didnt really under stand maybe some one could help me out on that.(it was somthing about were the studs go in it acualy streches were the bearing lays into??) So i guess my question is, is it super important to do arp studs on your main bearing caps if im only planning on running 15psi? any info would be sweet so i can figure out if im gunna drop the extra money or not.
I'd ask him all the details to be sure.
ARP head studs and rod bolts are a must, but I used OEM main bearing cap bolts.
And i didnt know that about the ctr and itr cams thanks for the tip lol. Guess its crower ftw!
Only thing on the main girtle is my buddy has built lsvtec stock sleeves no girtle and runs 17psi on a gt30 putting down about 320whp so thats the only reason im undecided.
