- Wed Sep 16, 2009 11:09 am
#144080
I just put a turbo kit on my sol (3 days ago)
its only about 5 psi but has seen spikes up to 8-9 (getting new waste gate today and its only happened twice)
well because of the low pressure i thought i could get away with not making a catch can.
this morning under the crank pully area there was a basket ball sized oil spot and after the engine warmed up i started seeing smoke coming from between the engine and firewall on the drivers side.
i think either
A) the little black box on the back side of the engine blew off (pcv breather box of some sort)
B) the crank seal got pushed out
C) oil is being forced out of the crank seal
because i didn’t see it actively leaking out i don’t think the crank seal was forced out so i think B) is out the window and because it was smoking from the back drivers side of the engine without any exhaust running thru that area i don’t think its C) either
witch leaves me with the quick fix of option A) (Please let it be A))
go home pop the black box back in, grab two bits of tubing and re-route the pcv to an old monster energy can with a filter on it!
Im currently stuck at work mulling this over in my mind with no one to bounce the ideas off of, and no way of troubleshooting it till i get home (10 hours from now). Its driving me nuts!!
please some one, just let me know if this makes sense
i think either
