- Thu Jun 11, 2009 11:15 pm
#122456
Ok, so I boosted my car about a week or so ago and everything has been running fantastic and all except for this one little problem, after a few days of driving it, it started to leak a little oil, I mean like 4-5 drips when I park it and come back a few hours later from the hole where the return fitting is in the oil pan, my question is, is it leaking from there possible because my oil is too high in my pan and it's kinda over full (my oil goes about 1/4 inch above the 2nd mark on the dipstick). or is it really leaking because the oil pan is pressurized and it's pushing oil out? I had it sealed up, but I think it's leaking through it a bit now? Also, any other suggestions to fix this hopefully without having to drop the oil pan again =/
Sorry for the wall of text, and thanks for the responses
as well as tighten up the nut on the other side, but it still leaks a little bit, do you think it would not leak if the oil was down more towards the top mark? Or do you have any other suggestions?
not to mention any time I have to pull it I have to pull my down pipe too, which is the biggest issue since its impossible to get on yourself, and it's still retarded hard to get on with 2 people.
