since i'm gonna be runnin a kind of big intercooler, I figure i'm gonna have some boost loss with the WGA getting its vacuum source from the end of the compressor outlet. is too much psi loss gonna cause a problem for tuning??
and if I'm understanding what i'm reading, I can run the WGA hose to a vacuum block by the IM safely with a good BOV in use to fight the comp surge, and get more accurate psi that should match what the boost guage reads....
got inputs?? thumb up
And....
Whats the deal with gap around the "plunger" of the wastegate. seems like it would let quite a bit of exhaust past?? i thought mine may be missing some sort of seal there, but i guess not..
best pic i could find. you can see light around the plunger (the gap) whats up with this??
