- Fri Mar 13, 2009 12:24 am
#102731
Hey guys, finally borrowed a camera an took a few shots, she still has more work to be done.
new info updated 1/27/11
Goodies:
~Engine:
JDM B18C- ITR pistons, skunk2 stage 1 cams, skunk2 pro cam gears, skunk2 valves/retainers, skunk2 intake manifold(port an polished) skunk2 68mm throttle body(port an polished) Comptech intake, full skunk2 exhaust, replica Hytech Header w/ custom test pipe, RC 440cc injectors an a oem ITR LSD tranny! (A/C an power steering removed) fluidyne radiatior, traction bars, hasport motor mounts, optima battery, ITR valve cover gasket set, ITR oil cap, hand painted gears of war valve cover, password jdm washer/bolts, benen radiator stay, greedy cooling plate, jdm fuse box cover, CTR crank pulley
11:4:1 Compression-- 93 octane tune-- vtec is set to 3800 rpm an redline 8800 rpm
an the numbers are 190 whp an 129 ft/lbs
~Suspension/brakes/wheels:
Skunk2 front strut bar, skunk2 rear lower arm bar, omni power LCA, neuspeed race springs with KYB silver struts, Civic Si disc brakes all around an sitting on 14" Mugen MR5's lips been repolished wrapped in Falkens, jdm ego dice valve steam caps an muteki neo chrome extended lug nuts
~Body
Factory Supersonic blue pearl with a little extra purple pearl throw in the mix only can see it with more light, painted roof black,oem jdm headlights w/ working city lights, oem jdm clear corner lights an correct wired up oem sidemarkers (only light up when blinker on), oem DOHC vtec decals, antenna block off, oem civic complete nose mask, real japan front tag, oem rear civic emblem, oem sir decal, oem lsd rear hatch glass decal, Japan parking decal, an JAF decal, japan registration/emission decals, carbon fiber duckbill an front lip both spoon style replicas, JDM thin moldings, passenger side mirror block off
~Inside
Complete Civic Si black interior, jdm ITR Recaros, momo shift boot, momo bennenton steering wheel, nrg hub with spec d quick release an nrg wheel lock, mugen shift knob with circuit hero shifter extender, jdm road flare, Wink mirror, oem Honda radio block off plate, SiR Coin pocket, jdm gauge cluster
more to come.
Goodies:
~Engine:
~Body
~Inside
more to come.
'88 CRX SiR- RHD, Glassroof....
'06 Element EX-P- Daily
