By Si19809
#100903 CAR: 92 Civic Si HatchBack
It Had A "Ls Swap" =) I Have Chirped 1st 2Nd 3rd & 4Th AT 25MPH
B18B1 1.8 Non Vtec
The Timing Slipped So We Rebuilt The Head With A B18A1
The Tranny Was A Ys1 Cable Converted To Hydro
Block Ended Up Being Bad Also
So I Put In My
D16Z6 93 1.6L SOHC Vtec
With A 00Civic Tranny D16Y8
IN THE PROSSES OF A FULLY BUILT LS TURBO WITH STAGE 3CLUTCH & LIGHT FLY WHEEL.. CHIPED ECU LAUNCH CONTROLE 10 - 11 SEC HATCHY I CANT WAIT.
#100907 A bit OTT with the blue there, you even painted the radiator and fan. Apart from the rice lights / wheels and shark-fin roof aerial. It's ok.
Also are you firing on all cylinders? Cause one of your HT leads isn't pluged in to the dizzy in that last pic.
Edit:- What's that ghetto wire in the footwell on the drivers side for?
By Dippin_EG
#100959 I like the outside color. But needs to loose that steering wheel cover.
By Classiccarsrule85
#100960 definately like the outside blue color....and j/w the integra back seat did you try using the stock civic rear backing to fill in that gap?
looks good so far but definately far from finished im sure keep up the work.
By EgCruiser
#102332
