#68302 Yes, that is her name. I have to name my cars. That and I have two 93 Si hatches in the same color. I confuse people with that all the time. This makes it easier for them to figure out which one Im talking about.
As Some of you know, I had a botched attempt at lowering my car a while back. Ended up looking like this.
Well, I have recently corrected that problem with a new ...cheap set up. And new tires. This is what my Rayne looks like now.
And just to show you how low the font is. This is with my Blackberry pearl.
Its on a set of sleeve type coilovers with them adjusted ALL the way down. And by that I mean, there is no way it will go any lower at all.[list=][/list]
Last edited by Greasedmonkey on Fri Nov 23, 2012 5:04 am, edited 20 times in total.
By Faded_Milano
#68309 damn! Got Rubbing?
#68313 None. I checked on the way home too. Lock to Lock with no problems. I did want the back a bit lower too. Kinda sad about that.
By a_CoUpE
#68329 looks way better!!
By kel
#68353
#68358 Yes, I did it myself. It was rather easy, but Ive been doing this sort of thing now for 12 years, so most of it is easy. Not my first rodeo. Ride wise, well, you get what you pay for. its not the best. its bouncy and stiffish. Then again it will be changed out again soon enough. I just needed to fix the last attempt.
By Civic_HatchSI
#68360 I dont understand how you cant rub?! Mine isnt even half that low and it rubs.
By biretsu89
#68443 awww... fine... lol... good stuff though... what struts are you running?
By Got_Purp
#68470
#68542 I got a little agressive on a turn today, and it rubbs a little since the springs on the coil overs are not that stiff. I need to roll the rear quarters for when I put on the washers for the camber. I dont want to rub then.
I will also be puttin on my amber corners tomorrow since I have nothing better to do. So I will be posting up more pictures tomorrow after that.
