By spinksy
#55666 yo well thought id start a build up, as in a proper one.
heres my spec list again (added a few things from last time that i forgot)
engine-
B16a2 conversion
-DC sports 4-1 header
-twister decat
-megan racing stainless system (being replaced with an apexi N1 system next weekend)
-spoon panel filter with custom airbox
-GSR throttle body
-skunk2 pro series intake mani
-EK9 N1 crank pulley
-AEM fuel rail
-B&M fuel gauge
-AEM fuel regulater
-apexi neo vtec controller
-samco silicone hoses
-K1 10mm racing ignition leads
-spoon sump heat wrap
-hamp oil filter
-skunk2 1.3 bar radiator cap
-Buddyclub racing spec condenser
-power steering removed
-mugen replica rocker cover
-spoon socks
transmission-
-stage 1 exedy racing clutch
-exedy 9lb flywheel
-funky power short shifter
-energy suspension polybush shifter bushes
exterior-
-carbon fibre bonnet (with bonnet pins)
-carbon fibre shaved style tailgate
-carbon fibre spoon lip
-spoon style mirrors
-sunroof plated over
-JDM plastic headlights
-JDM rear outer lights
-JDM LED brake light spoiler
-cut rear bumper with anti-parachute holes
-JDM wind deflectors
-side trims removed
-rear glass spring locks
wheels and tyres-
-14" unknown JDM alloys
-firestone tyres :D
-K sport forged alloy lightweight wheel nuts
interior-
-JDM coin pocket
-stripped interior(no rooflining, boot trim, cut rear 1/4 plastic panels, all sound deadening removed, no sterio, no speakers, airbags removed, centre console removed)
-black lsi carpet
-custom carbon airbag tray
By spinksy
#55667 well had these awhile so went to fit these tonight-
started on drivers side but had a problem -
snapage!!
as you can see it snapped just above the joint when i was undoing the joinning connector things-
will be going to wilcos tommorrow to get some more brand new brake lines and a brake line tool (to flare the ends)
another quick pic of the old crappy brake line of the car -
so after tommorrow my car will have Goodridge braided hoses and brand new copper brake lines :thumb: [/img]
#55671 How much did they set you back? Mine are rusted.
By spinksy
#55676 the braided hoses were about £40 off a shop on ebay.
upgrading from the normal crappy rubber hoses to braided hoses helps and improves brakeing loads! :)
By spinksy
#55725 well went out this morning an bought these-
brake flaring kit and new copper brake lines (and some male adaptors)
first end of new front brake line flared-
alittle while later-
first side on
and other side front-
so thats that done (will be doing rears tommorrow/next weekend)
and a quick engine bay shot-
went for a quick drive and brakes are fine - although car is running bad. missfiring through the rev range and when vtecs about to kick in she missfires and backfires badly!!! :? :cry:
By vtec_gloucester
#55727 do a compression test dude.
i had bad miss fires through out the re range on my old civic... did a compression test and it wasnt good. i had 4 bent valves :thumbdown:
By spinksy
#55729
By spinksy
#55731
By vtec_gloucester
#55746 lol. sorry dude, do the plugs and leads first... see how that goes. have you checked the dizzy cap?
you'll be able to get one of them tools at any motor factors for about a 10'er.
also, have you check for fault codes?
By spinksy
#55758
By spinksy
#55852 well some GOOD NEWS - the missfire issue is sorted!
went to wilco again this morning and got 4 new NGK spark pugs and some new ignition leads. put them all on and hey presto shes running loads better!
was quite funny actually - i put all the bits on the car down this quiet road near my house - then put my foot down in 1st to see if vtec engaged properly -an it did - an it actually made me jump lol i was like fuck, that felt quick :woot:
(will be replacing the leads with magnecore ones when i got some money though as the leads i got this morning are cheapos - i think ive actually seen chow mein noodles thicker :lol: lol, but they work which is the main thing)
