By EgCruiser
#80876 snygga deler grabben hehe :thumb:
By Mordiiax
#81133 Thanks :) To bad my very old laptop need a replacement. Or else the car should have been complete by now ;) I just had to order one of these and they are quite pricey :S
As my first project i will make a garage movie about the Civic :wink:
By Mordiiax
#83325 Just in and i got a serious hard on since this is pure porn :D
Just some bushings to the DC2 swaybar and a couple of bolts left to buy, then it is time to fit all the goodies to the car :)
By EgCruiser
#83335 ah, snygt som Peter Forsberg spiller bra hockey hehe :thumb:
By Mordiiax
#83344 Hehe, i live about 90 kilometers from Peter Forsbergs hometown. I have met him several times and got a few autographs :D It was always a pain to play hockey against "MoDo" :x
By Mordiiax
#85157 Washed my daily driver this evening and let it dry in the garage since it is -17 degrees celcius outside :oops:
Meanwhile i did some work on my car :)
Click on picture for bigger version
First, jackstands for the rear
Stock Civic
I had these replaced this summer and the mechanic screwed it up. The bushings where so lose they fell right off! This and +1mm toe out = wobbly wobbly
One lca down. Simple job. Three bolts.
Function 7 lca installed. A bit fiddly to do this when you are alone actually since you need to push and get the bolts in to the holes at the same time.
Both lca installed. Still stock swaybar and no ASR.
Stock 16mm swaybar removed
ASR plate installed. Simple bolt on. A great tip is to install the plate BEFORE lca´s since the inner lca bolt goes through the plate. And the back piece is kind of hard to get in place with lca mounted.
Now we are talking :)
Another view
Blox endlinks. Not sure how to install these properly. Any ideas?
Close-up
Backside
ITR 23mm vs stock ESi 16mm
One problem i came across you see inside the red cirkel. The bolt head is not in the center so my tools where to thick to fit. I wonder if the hardware store is open tomorrow :D
By EgCruiser
#85158
By Mordiiax
#87151 Got the swaybar in place today
And stripped out the interior. Any ideas what to do?
Of course i would like to get rid of the black stuff (called what?) and paint it all white, but that is really boring :P
By insigma
#88759
By EgCruiser
#89511
By Mordiiax
#89577 Dry Ice ftw!
Big difference in dry ice vs heater gun
And the interior is getting a bit brighter...
I got some Honda OEM parts for removal of the rear wiper.
The motor is quite heavy!
By Rick_EG6
#89592
