By Mordiiax
#309578 JRSC :)
With LHT intercooler!
By Mordiiax
#309941 Clutchmaster FX400 clutch *check*
Spanking new master brake cylinder *check*
Now i need an ethanol friendly fuel pump and fuel injectors. Then we are ready to convert to blowing! :)
By Mordiiax
#311580
By bks84
#311599
By Mordiiax
#311909 Did some styling.
By Mordiiax
#312019 Image
By Mordiiax
#312426 Swapped the gearbox from S9B to S80 with 4.8 final drive. Also installed Clutchmaster FX400 clutch.
And some pictures :)
By Mordiiax
#313225 Track!
By dbrooks
#314867
By Mordiiax
#315294 Thanks :)
Some JRSC LHT questions:
I will be running with E85 fuel (15% gasoline, 85% ethanol). Recommended size in fuel injectors?
Recommended brand of injectors?
What is the need of fuel pressure regulator?
Anything extra i should now? Tips and trix learnt my mistakes an so on? :)
By Mordiiax
#317159 Zzzleepy time!
By Mordiiax
#332669 Welcome back into the sunlight :D
Removed Full-Race traction bar. Installed bronze bushings in front control arms (upper and lower). Some new nuts and bolts here and there. Brand new Denji headlights.
The front is removed becouse it needed a "re-wrap" :)
