- Sat Jun 07, 2014 6:47 am
#346233
- Fri Jun 13, 2014 8:36 am
#346423
- Sat Jun 14, 2014 1:20 pm
#346442
- Thu Jun 19, 2014 3:16 am
#346565
Stockin' up on some more parts. =)
Just picked up a full set of D/B Series Drop Engineering Motor Mounts!!!
These things retail from DropEngineering.com for $320+shipping.
A got these off a guy on Kijiji that lives in British Columbia for $60+$20 shipping.
So for $80 I picked these bad boys up! =)
- Thu Jun 19, 2014 6:50 am
#346574
- Thu Jun 19, 2014 6:58 am
#346575
- Thu Jan 08, 2015 4:32 am
#350867
So I know I haven't posted in a long time! Haha, but I finally have. HUGE UPDATE!
I'm going BOOST! I have put a whole kit together just for getting it boosted and I might pick up some more quality parts later on. But as for now this is my list. =) Enjoy
EG Turbo Kit Setup
CT26 Toyota Supra Turbo
- CNC'd CT26 to T3 Adaptor Plate
- CNC'd Exhaust Outlet Flange
- 2.5" V-Band Flange & Clamp being welded on the turbo exhaust outlet
- Titanium Heat Blanket
- K&N Slim Air Filter
- 10AN Oil Drain Line & Fittings
- 4AN Oil Feed Line & Fittings
- 4AN Coolant Line & Fittings
FullRace T3 Top Mount Turbo Manifold
- Almost Brand New 2000km Used
Tial 38mm V-Band Wastegate & Custom Welded Dump Tube
- V-Band Clamps on both Wastegate & Dumptube Sides
- Current 7PSI Spring
- Additional 10 PSI Spring
2.5" EBay Downpipe
- Intend to weld V-Band Flange & Clamp to mount to Turbo
- Have to custom make to fit properly still.
Chipped P61 OBD1 ECU
- Chipped with a SST 27SF512 Re-Burnable Chip
- Currently with a P30 Basemap
- All Sensors Working
- Soldered in Zero Force Insertion (ZFI) Socket for easy chip removal
- All Main Capacitors Replaced
- All Professionally Done
BLITZ Super Sound BOV
- Has two outlet attachments, one filter and the other is open
- 2 Springs, One for soft and both for hard
- Brand New
- Missing Vacuum Line
EBay Intercooler
- Painted Flat Black
2.5" Charge Piping
- Professionally PowderCoated Black
Stage 1 Snow Performance Methanol Injection Kit
- Switched Solenoid to shut off
- Brand New In Box
440cc DSM BlueTop Injectors
- Pigtails Included
52mm Prosport Evo Digital Boost Gauge
- With Sending Unit
Miscellaneous Parts
- VMS Mechanical Liquid Filled Fuel Pressure Gauge
- NGK 7 Heat Range Spark Plugs
- Oil Pressure Sending Adaptor for Oil Feed to Turbo
- 10ft of 4AN Stainless Steel Line
- 3ft of 10AN Stainless Steel Line
- Titanium Heat Wrap for Downpipe
- Weldable Bung for Oil Pan
- 2 Weldable Bungs for Downpipe, O2 and Wideband
I am so stoked to get all of this in and going, I am currently buying a Built Head and Block USDM B18C from a buddy of mine for this to all mount up to! =)
But I am still in the process of shaving the engine bay and finishing up the full engine tuck and brake line tuck. I can not wait for all of this to be put together! AHHHH =)
I hope this update was enough, thanks for reading guys!
EG Turbo Kit Setup
2.5" EBay Downpipe
- Brand New
EBay Intercooler
2.5" Charge Piping
- Brand New In Box
- Pigtails Included
- With Sending Unit
Miscellaneous Parts
- Thu Jan 08, 2015 4:54 am
#350871
awesome update dude
pretty dam nice setup for your first time under pressure
- Thu Jan 08, 2015 4:58 am
#350872
