[phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 488: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead
[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4868: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3937)
[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4870: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3937)
[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4871: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3937)
[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4872: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3937)
Civic EG • View topic - Can a 00 civic si fuel and temp gauge fit my 92-95 cluster
PostPosted: Thu Jan 31, 2019 7:59 pm
by Ej1vellii
I want to to take apart a si cluster and put it in my 92 civic coupe and I know the the speedometer tach doesn’t fit but will the rpm and fuel temp fit ???
Re: Can a 00 civic si fuel and temp gauge fit my 92-95 clust
PostPosted: Fri Feb 01, 2019 6:42 pm
The clusters are completely different, so I'd be 99.9% sure in saying they aren't compatible. Physical dimensions are one issue, but then the electronics are going to be another possible issue.
Anything is possible though with enough fabrication... just make sure you're up to speed with an ohm/voltmeter and electrical wiring.
PostPosted: Sat Feb 02, 2019 1:56 pm
by Ej1vellii
Ok thanks
