Door locking issue
Thu Jan 29, 2015 2:47 am
by Josh721
I just bought a 95 hatch and the driver door won't lock. The car has manual locks I've read a few things it being the latch itself in the door which it very well may be so far as I have checked. But before I buy the lock latch, the driver door lock button on the inside is missing, would this have anything to do with the door not locking as well?
Thu Jan 29, 2015 4:37 pm
by egsedanguy
you should take the door panel off and just look. it could be a bent or binded lock rod. or the lock itself. best to just look and not play the guessing game. And the fact that its manual lock, then it should be an easy fix since there is no electrical.
Fri Jan 30, 2015 2:03 am
by Josh721
Took off the panel, everything is there. The lock latching just seems to be getting stuck. I just bought this car and I think it's been sitting with the all all the dust is everywhere. Maybe wd40 the latch tomorrow. I got it to lock, but only after I unlock, then lock it right after, if that makes sense.
Fri Jan 30, 2015 3:46 pm
by egsedanguy
Does it do it when locking/unlocking from the outside with a key and/or from the inside?
Fri Jan 30, 2015 7:35 pm
by HeikDiesel
If you're locking it from the inside you have to pull the handle before you cam the lock lever over.
Fri Jan 30, 2015 8:41 pm
by egsedanguy
HeikDiesel wrote:If you're locking it from the inside you have to pull the handle before you cam the lock lever over.
yup. I forgot about this.
Sun Feb 01, 2015 5:27 am
by Josh721
Didn't even think of that. That's how I used to have to lock my rsx. But to lock this car from the outside I have to unlock it hen lock it. Is that pretty typical? The lock button on the actual door handle is missing so the lever that would hold onto the lock button has nothing to latch on.
I can lock it from the inside with the lath but only when the door is closed.
