[phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 488: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead
[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4868: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3937)
[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4870: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3937)
[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4871: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3937)
[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4872: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3937)
Civic EG • View topic - DIY swap oem gauges in your cluster
PostPosted: Sat Jul 06, 2013 2:32 am
by eg-guy
If you have a broken gauge in your cluster and don't want to spend an arm and a leg for a used cluster, here's a great alternative. I picked up a auto dx cluster for $20. You can purchase individual gauges on ebay. Luckily the mileage isn't off too much between the two. Here's a comparison.
Uploaded with
There's six tabs circled in yellow, press the tabs and remove the cover.
Uploaded with
Next remove these screws circled in red.
Uploaded with
Carefully lift the gauge you wish to replace. It comes strait out.
Uploaded with
Repeat the first steps with your donor and carefully lower the working unit in place.
Uploaded with
Replace the 3 screws and pop the clear cover back on. Enjoy your working cluster.
Uploaded with
The hardest part about this was removing the hazard button and trim inside the car. Very simple. Hope this helps someone.
PostPosted: Sat Jul 06, 2013 3:56 am
Thanks! added to the DIY list:
http://www.civic-eg.com/viewtopic.php?t=1474 :thumb:
