quick LED cluster question
hey all, i got T10 LEDs.. will these replace the stock bulbs behind my cluster? thanx in advance
https://forum.civic-eg.com/
HAFIL0_EG wrote:T-10 globes are only good for parker lights and rear number plates, you need T-5 globes for the dash and heater controls as well as ash tray. and for the hazard buttons have even smaller globes again. and you will need wide spread LED globes for the dash otherwise you will have dull spots with normal type LED globes, hope that helps
chorean wrote:HAFIL0_EG wrote:T-10 globes are only good for parker lights and rear number plates, you need T-5 globes for the dash and heater controls as well as ash tray. and for the hazard buttons have even smaller globes again. and you will need wide spread LED globes for the dash otherwise you will have dull spots with normal type LED globes, hope that helps
Any advice on climate control swap? Cannot figure it out for the life of me.
HAFIL0_EG wrote:chorean wrote:HAFIL0_EG wrote:T-10 globes are only good for parker lights and rear number plates, you need T-5 globes for the dash and heater controls as well as ash tray. and for the hazard buttons have even smaller globes again. and you will need wide spread LED globes for the dash otherwise you will have dull spots with normal type LED globes, hope that helps
gave you some info on my build thread champ
chorean wrote:HAFIL0_EG wrote:chorean wrote:HAFIL0_EG wrote:T-10 globes are only good for parker lights and rear number plates, you need T-5 globes for the dash and heater controls as well as ash tray. and for the hazard buttons have even smaller globes again. and you will need wide spread LED globes for the dash otherwise you will have dull spots with normal type LED globes, hope that helps
Thanks, dude!
