#178034 Should fit. Where is it hanging up?
By Classiccarsrule85
#178040 I did this conversion there are acutally a coupe things you need to trim theres a plastic p[eice on the air bag side (even tho it never came with one) you need to cut that off i think itd be easier to find if you had the glove box off....besides that it should slip over as long as you removed all teh brackets etc
By momoyouknow
#178065 the problem is the glove box won't fit there's a bar on airbag side that isn't there w/ my 92. do i needa remove the air bag computer to have it fit or is that irrelevant?
#178069 ok thats irrellevant take a pic of your dash if you could and try and get the problem areas i know wtheres like a plastic drop down that has cut out spaces in between where the p.side airbag would go if you will i just cut that out and discarded it and it fit perfectly if you post pics ill ms paint what you need to cut
By momoyouknow
#178185 Image
the glove box is hitting that metal thinger on the left :x
#178187 Image
that you need to cut out first or the dash wont sit correctly..... hopefully that helps
By momoyouknow
#178237 so the cars being borrowed till the end of march i'll get to the cutting when i get it back.. thanks for everything :thumb:
