By mistergou
#173588 Hey guys, tired searching for this an did not find anything...
well my ITBs got stuck one day at WOT an cause my tach to rev passed 9k RPM before I could get car turned off...
I got the car running fine now, but had to swap out gauge clusters because the tach needle is stuck around (if there were numbers there) 11-12k would be an only moves a little bit...
do I need to just take gauge cluster apart an take needle out an reposition it?
is there a secret trick I can do ?
s.o.l. ?
#174478 Take the clear face/cover off the cluster and just re-position it. Did it with mine when I had it and it worked fine! No tricks Its pretty self explanatory. GL
By mistergou
#174536
Chance wrote:Take the clear face/cover off the cluster and just re-position it. Did it with mine when I had it and it worked fine! No tricks Its pretty self explanatory. GL
thanks chance :thumb:
By DontHateonEG8
#174538
was your needle intact with your needle?
