By MEANGREEN22489 - Fri Aug 15, 2008 1:45 am
#66040
Whats up guyz
I took down the trans in my 92 coupe because the clutch fork was cracked and ended up replacing the clutch flywheel rear main seal etc during the dismantle i had to take out the shift linkages one has a 12 mm bolt the other has a boot and a clip i know now, but i didnt take that out i took out the pin thats on the shifter bushing now what should i put in there now. Should i just put in a OEM pin or could i use a grade five bolt lock washer and nut
Mean Green Casey K
